Which Cam should I Go With?
#16
Re: Which Cam should I Go With?
Originally Posted by BUBBA
Anything larger (again this is just my opinion) you might be compromising the idle, the low end tQ that comes stock with the Lt1, and the longevity of your bottom end with your 2 bolt mains.
#17
Originally Posted by BlkLT1Z28
well, your name is Bubba........thats an automatic -20 points of yer IQ
lol! Ive met some intelligent Bubba's, but that was only there nicknames
#18
Originally Posted by 95WhiteTA
well yeah i can get a CC306 on any LSA, if i wanna pay out the *** for a custom grind, but i'm not trying to blow too much money on a cam, i want some cash left over for some 1.6's.
As for the lift guys it's all part of the system, sticking to a lower lift might hurt you depending on the lobe area, the duration and a few other factors.... in reality the springs, rocker arms and budget are what limit valve lift not arbitrary factors, and ESPECIALLY not head flow. If your head flow drops off at higher RPM then you have more problems than you know how to solve.
Bret
#19
When I started all this, I was skeptical about my cam selection. I trusted Lloyd and his decisions and what Bret ground the cam too. For as skeptical as what I was, the first time it fired it and got to tromp on it, I was all smiles. I am a believer now, without a doubt.
#20
BTW the billet cores are more expensive no matter who you get them from, now they got worse since you have to run a bronze gear OR pay extra to get the oil pump drive/distributor gear heat treated to work with the stock gear drive.
Bret
Bret
#21
Perfect candidate for a HOTcam. Will work really well with the 3200 stall! I had a HOTcam and some home ported heads on the stock bottem end. Ran 8.1 @87 in the 1/8th on a mail order tune, bolt ons and 2800 stall. It really needed some more stall because I could dead hook it on the track and pull 1.8 short times.
BTW, got 22 mpg with that setup on a 75% highway/25% city driving trip.
#23
they might charge your friend more, but bret's results may vary on that one.
and bret whats up with the heat treating on the dist gear now. they quit pressing the cast iron ones on, or just raised the price on that?
#24
Bret
