cam spec Q's
cam spec Q's
I've spent over a half hour google'ing and reading goofy posts and even got on GM's site that I typed in the #'s and NOTHING came up..
I have two cams.
--Cam 1= 241 cpc bc 1 ---Supposed to be a LT1 cam but would like to know the ACTUAL specs, and not "DUDE.. That's the same one I got!!!" or "Yup, It's aLT1 cam alright..."
--Cam 2=(at the back of the cam, by the plug) HOW IT'S ACTUALLY STAMPED!
1264
2 00
6143
(UNDER the two breather holes)
F 4
Thank you for your time.
E
I have two cams.
1264
2 00
6143
F 4
E
Re: cam spec Q's
Best guess I can offer is sometimes a pair of 4 digit numbers like you say is on the second cam can be lobe numbers. I can tell you searching Comp's 2010 catalog neither of those is a Comp lobe number though.
I don't know if that can help or not, at least now you have some idea of what numbers could mean.
Can you post pics? Not that I think anyone can visually identify cam specs but maybe the way something is stamped or etched could be familiar to someone.
Brandon Wittmer
12-20-2014 09:51 PM
