Cam Sprocket on LT4 Extreme Duty Timing Set..
If I look on the gm parts web page, it says the Extreme Duty kit consists of the heavy duty chain and crank sprocket used in the zz 350? I see the one you gave me is different? The ones it gave me part numbers for are 14088783 (chain) and 14088784 (crank sprocket)?
just did a search on this forum for "Extreme Duty timing chain part number"... lo and behold the very first thread:
http://web.camaross.com/forums/showt...in+part+number
That dont help me any... if you go on gmpartsdirect.com and type in the p/n for the ed timing set at the bottom of the description it has a p/n for the crank sprocket and timing chain used in the ed kit.. So will 14088783 (chain) 14088784 (crank sprocket) work with the 12555885 (cam sprocket) shoebox gave me? Or is there another timing set out there cheaper than $250 that is good for a mild 383?
Originally Posted by what's in the ED set
Included in this kit are the following steel gears: water pump gear P/N 12551727, a camshaft sprocket, crankshaft sprocket P/N 14088784, and timing chain P/N 14088783.
The cam gear above is a non-LT1 cam gear for a regular SBC. It has no provision to run the water pump.
10-31-2016 11:09 AM
routesixtysixer
06-23-2002 02:29 PM
