Cam swap (to the smaller one :( )
#17
I'd take timing out and/or add more fuel. I really think, if you had a competent tuner street tune the car, you'd be happy with it. Honestly, the biggest difference maker in my car was the gears. I went from 3.73's to 4.40's and it made the car much easier to drive.
#19
Big cams aren't for everyone, but I do agree that you should try a 4.10
4.30 or 4.56 gear.
Big cams need big gears, hell I've got a Joe O. LE2 cam which is smaller
than yours and I've got 373's which I think are to little for me.
I'm gonna go 4.10 or 4.30's really soon.
4.30 or 4.56 gear.
#23
I loved my 4.40's. With a lean tune (15:1 a/f), I was able to get ~18 mpg. The only downside is you'd probably be shifting into 5th in the quarter mile; which is why I changed mine out to 4.22's. If you're road racing the car, I think you'd love gears that low. With the 4.40's, I was cruising on the highway at 70 mph @ 2k rpm. That's enough rpm to get it out of the surge area and not enough to cause horrible gas mileage.
#25
4.10 with a cam around 224/230 dur. ?!! OMG and I'm using 3.42 with my current cam. Okay I will definitely try the 4.10. I don't want to go with bigger because I never use my car in drag races. And top speed is also important to me.
25mpg is great, but I have not a problem in highway, I have a gas mileage problem in the city. So please give me your city gas mileages.
#27
Did you forget which transmission you have? According to this gear calculator, with 4.40 gears (just as a reference) you'd still be able to do 229 mph @ 6500 in 6th gear. You're car would never make it to that speed, but just saying that it's still possible.
http://www.5speedtransmissions.com/gear_calculator.html
#28
Hehe, tough to say what the city MPG is, if I'm driving in the city I use my right foot a lot. Although, I used it for the commute a while back and I believe I got ~20mpg in mixed driving with a good bit of stop and go rush hour type stuff. So that would probably put the city mileage at 15-16mpg if I didn't get on it much.
#29
Mine doesnt buck, and you can see the setup in the sig. My opion, is to find a dyno and find a reputable tuner to come tune it, put a 3.73 or better in it. If those 2 things doesnt suit you, then change your cam.
