Which cam would you run out of these 3?
#19
Re: Which cam would you run out of these 3?
engine? Hmm i thought i was in the LT1 tech section and i said 3.73's and its a M6 car, and in a post further down i mentioned what i was look for out of the cam.
Mid to low 12's
Idle - doesnt matter
MPG - doesnt matter
Must be somewhat driveable this car is my daily
Must react to a 150shot of nitrous well
and a useable powerband for a daily car ie below 6500rpms.
Mid to low 12's
MPG - doesnt matter
#21
I just said daily driver in the last post, stock compression, lt1 intake ported to match ported lt1 heads, i mentioned the 3.73's twice now, it will run on 93 octane 99% of its life. And it will also be sprayed with a 150 shot.
And 350cu, i havent touched the bottom end, like i stated earlier. Im building a new engine but its coming along slowly. and even then its only gonna be a forged 355.
#23
I'm assuming it's a stock 350 with stock unported heads and stock injectors as well as stock compression. (since it's a stock engine) He did say 3.73 gears.
Like I already said, I would go for the 227/233 on a 111 or 112 if you want.
I have the 233/239 and I need to shift it at around 67-6800 for best track times in an A4. You can see why on this graph. (sorry about the lame quality)
The 227/233 will make the same or VERY close to the same power as the 233/239 on stock heads but will bring your peak at a lower RPM and give you slightly better driveability. (although mine is VERY driveable except for the loud exhaust)
PS. This car made 5 RWHP/5 RWTQ more during the winter.
#24
Im planning on new injectors, and one day ill install the new fuel pump as well and the heads will be ported stock lt1s.
The 227/233 is definently gonna be what i go with, so long as Rich says it will work with nitrous.
#28
The 227/233 with a 112LSA and a 108ICL will work with the nos(don't turn it on until 3000RPM's) and stock compression,ported heads with 2.0" valves,and stock intake.
My preference would be 224/228 an a 112LSA and 108ICL 580-586 lift.Crower makes one and it should put you at 11.9-12.0's on motor in a 3600LB car with 4.10's and a stick.It makes peak power at 6200 and will pull to 67-6800 with good street manner's.
#29
Thanks racer dude, ill have to talk to them about a cam with those specs, and im guessing i should stay with a 112lsa or higher for nitrous as ive always heard. Thanks for your help guys, now i atleast have some ideas before i call them.
