Cams does it do this???
After a before and after a tune my oil smells a little gassy. Does this happen to yours. Also sometimes when I rev the engine and stop then turn around to start it back up there is a grey smoke. I think its just unburned fuel but not sure. I have not cat so I see and smell everything. Come on give me something to worry about!!!
Teacher teacher!
I've got a question... will a cam make the car rev a bit faster. I've got a bone stock car (torn apart of course) A4... adding ported heads, 230/236 cam, and a flywheel and clutch assembly thats about 25lbs lighter than stock.
Location: Austin, TX or Texas State University at San Marcos
The flywheel will make the rpm's rise and fall faster......the cam will allow you to rev higher so...............yes.
Chris
Jesse
