Camshaft Identification?
I cant remember the specs on it. It should be comp camps. Tried searching on their website without much luck. Ground into it are:
31225/31205
HR113
CC
N2803
-08 (might be 108)
If anyone can help me out it would be much appreciated. Thanks
31225/31205
HR113
CC
N2803
-08 (might be 108)
Re: Camshaft Identification?
Well Comps lobes for 3122/3120 is a 236/244 @ .050, HR usually means hydraulic roller, and 113 I'm going to assuming is the LSA. The lift for those lobes are .608/6.13 with 1.6 rockers. The lobes fall under the high lift magnum series and the Advertised duration listed is 290/304, hope that helps. Maybe try calling comp?
-Dustin-
-Dustin-
