Camshaft Install - LT1
Old 05-04-2011 | 03:03 AM
jpkalas's Avatar
How tough is it, REALLY, to do a cam swap on an LT1? What are the steps? Does the motor have to come down? I'd just love not to pay crazy money to have someone put it in.
Old 05-04-2011 | 04:53 AM
RamAir95TA's Avatar
Re: Camshaft Install - LT1
www.shbox.com has a great write-up on how to do it. Having done several of them now, it's about a 4 out of 10 for me, but the first time around was closer to an 8. It can be a bit intimidating at first, but if you follow everything to a T and have a GOOD COMPLETE set of tools (VERY important) it's nothing you shouldn't be able to handle.
Old 05-04-2011 | 07:06 AM
Ocala93TA's Avatar
I did mine and it wasnt bad at all , I didnt rush to get it done and even did alittle extra putting all new seals i could do new water pump new opti etc. You may want to do the same i hate going back and taking stuff back apart !
Old 05-04-2011 | 09:36 AM
johnnyb's Avatar
if you're too lazy to search the hundreds of posts that ask the same question, it's probably not for you
Old 05-04-2011 | 10:00 AM
94Camaro_Z_28's Avatar
It's not hard, you just have to pay attention to what you are doing. It can be done in the car if you remove the radiator/ac.
http://shbox.com/ci/cam_removal.html
http://shbox.com/ci/cam_install.html
Old 05-04-2011 | 03:52 PM
LSWHO's Avatar
It was easy. Just make sure you get the correct setup for pulling the balancer and putting it back on. That's the "hard" part.
Old 05-04-2011 | 05:20 PM
jpkalas's Avatar
Thanks guys!
10-31-2016 11:09 AM
edman
01-22-2015 02:45 PM
HCz28
01-11-2015 11:17 AM
1775.Z28
01-11-2015 10:51 AM
Quick Reply: Camshaft Install - LT1
