Can the Camshafter Retainer plate be welded on with cast iron block
Old 03-12-2008, 09:35 PM
az0884's Avatar
I snapped one of the small bolts that hold the cam retainer plate and have made a mess out of trying to drill it...its doesnt seem likely at this point that i can re-thread it....i was thinking of using an arc welder to weld on the retainer but ive read horror stories about arc welding on cast iron....anyone have any input or ideas/
az0884 is offline
Old 03-12-2008, 09:52 PM
kylersaulsbury's Avatar
it can be done but you have to be VERRYY GOOOD! so i'd say if your anything less than a master welder then don't try it.
kylersaulsbury is offline
Old 03-12-2008, 09:56 PM
mdacton's Avatar
Hell no, get someone who knows what they are doing to get the bolt out and fix it. Now its going to cost more since you worked on it and made it worse......
mdacton is offline
Old 03-12-2008, 10:14 PM
Cook Performance's Avatar
follow mdactions advice. DO NOT WELD ON YOUR CAM THRUST PLATE.
Cook Performance is offline
Old 03-12-2008, 10:17 PM
SS RRR's Avatar
oh god
SS RRR is offline
Old 03-12-2008, 10:19 PM
Steve in Seattle's Avatar
any chance you can drill it out, and tap it for an oversized bolt?
Steve in Seattle is offline
Old 03-12-2008, 10:22 PM
greenmachinedriver's Avatar
drill it out and install a permacoil. do not weld it
greenmachinedriver is offline
Old 03-12-2008, 10:26 PM
GreasyB's Avatar
What in the world are you thinking....
GreasyB is offline
Old 03-12-2008, 11:09 PM
The_Bishop's Avatar
Wow, now I have heard everything.
The_Bishop is offline
Old 03-12-2008, 11:10 PM
danhr's Avatar
i bet you don't do it
danhr is offline
Old 03-12-2008, 11:29 PM
marshall93z's Avatar
Do it and call me when you wanna take your cam out.
marshall93z is offline
Old 03-13-2008, 12:01 AM
69gto96z's Avatar
I would strongly recommend against welding it. Plus, if you need to change the cam at some point, you will be screwed...
69gto96z is offline
Old 03-13-2008, 12:38 PM
Pro_built7's Avatar
holy @#% no no no do not do that oh god please.
drill it out and tap it for a bigger bolt. how did you make it a mess ?
if that can't be done helicoil.
Pro_built7 is offline
Old 03-13-2008, 12:59 PM
Guest
guest74777's Avatar
welding the retainer plate to the block...wtf?
guest74777 is offline
Old 03-13-2008, 02:43 PM
rickyzZ28's Avatar
The motor I put together for Penz on this site had the plate spot welded on when we took the motor apart. We were both like WTF. I took a screwwdriver and hammer and hit it 1 time and it fell on the floor. I wish I would have taken a pic of it first. The guy who assembled the motr before us must have been a real idiot.
rickyzZ28 is offline
Quick Reply: Can the Camshafter Retainer plate be welded on with cast iron block
