Can a distributor be use on an Lt1?
If going to a carb. style manifold and actually making the car carbeurated can you use a distributor on an LT1 or is the hole not there in the block? and if it's not there could I have it machined into the block?
Re: Can a distributor be use on an Lt1?
yes it can accept a standard distributor. I've done the carbed conversion before and it worked. pretty easy, makes the engine compartment alot more good looking.
stockssn2o
05-25-2015 08:54 AM
