Can I move radiatior to where a/c condenser was?
Having gotten rid of the compressor almost a year ago to rid myself of the squeal, I finally got rid of the condenser this weekend which got me thinking...
Has anyone moved their radiator forward to where the condenser used to be?
I figure the car could benefit from some new radiator hoses anyways, so if I have to get longer ones, that would be OK. I don't really know if the trans cooler lines are long enough though. And the top radiator cover, I figure I can drill new holes in it and just remount it. If anyone has done this and has info or part numbers for hoses they'd like to share, I'd appreciate it.
I know the FI guys are all about getting smaller radiators and mounting them vertical, I don't need to do anything that drastic, just figured if there was an easy way to get some more room between the fans and the pullies, it might come in handy for working on the opti or water pump or whatever.
Thanks.
Thanks.
Thanks.
Thanks.
I don't think the rad hoses even need to be changed and I have a B&M supercooler so there is some flexible line there and that won't have to be replaced either.
Thanks for the good info, I'm gonna take a closer look this weekend and see exactly what it'll take to move it, if it costs too much in time or money, it ain't getting done.
I moved the rad. AC delete, but, I think I could fit the AC condensor with some re-plumb. I like the added room, and, more air flow/ heat off the front of the engine. Did it winter of 07. B.
http://s306.photobucket.com/albums/nn244/mzgp5x/
Some have moved the stock radiator into the vertical position... You cant really put it where the condenser was either... I went after market rad and mover vertical, just finished new fan install had to run duals...
About 11inches from pump to radiator LOTS OF ROOM!
Nayr
03-03-2023 08:34 PM
