Can I start the engine without a trans attached?
Old 05-14-2006 | 12:00 PM
Ekof96Z28's Avatar
Hey guys, as it states. I have 30 days of warrenty on the engine I snagged from the bone yard. Will I be able to start it up and let it run and mildly rev it a bit to make sure its solid without a trans attached if I cant get ahold of one in time?
Old 05-14-2006 | 12:28 PM
urbaNHunter44's Avatar
Re: Can I start the engine without a trans attached?
Yes you can but I wouldn't recommend it unless it's absolutely necessary. It'll jump around alot.
Old 05-14-2006 | 12:50 PM
Birdman7389's Avatar
Be forewarned....Its gonna sit at a crazy angle wit no trans for support. The engine will also rev up very fast with no clutch or converter attached.
Old 05-14-2006 | 01:33 PM
Loadre's Avatar
It'll be fine. Will surge a bit and might run a little rough depending on how close your O2s are from the open air.
Old 05-14-2006 | 01:49 PM
cammed_aro Z28's Avatar
should be fine, if it is in the car, i would prop the motor up with some 4x4's or something so it sits like there is a tranny in the car, my thinking is so that you dont stress the motor mounts too bad. i have started motors without trannys before, they just rev really fast. i wouldnt recomend revving the ***** out of it like previously stated
A's 91 Z28
01-11-2015 10:58 AM
hotrodyou1
12-20-2014 10:05 PM
Injuneer
12-15-2014 09:36 AM
07-04-2005 05:00 PM
Darth Xed
13
07-22-2002 12:45 PM
Quick Reply: Can I start the engine without a trans attached?
