Can I use a 1996 Hooker Cat-back with pacesetter longtubes on a '95 Car?
I'm assuming this would work fine because the pacesetter y-pipe eliminates the cats anyway, just wanting to make sure it will work before I go through with a trade for my true duals.
Re: Can I use a 1996 Hooker Cat-back with pacesetter longtubes on a '95 Car?
Yeah, you should be able to do that without any problems. I have Pacesetter LTs and Y-Pipe with a Hooker catback on my 96 and it fits and sounds great. It should be no different on yours. I had to have the Y-pipe expanded just slightly to fit over the Hooker I-pipe but thats about it. (I also had to dremmel off some weld beads off the inside of the tubes on the Hooker muffler where the tailpipes insert - just a heads up).
Yep..mine fit up fine, just had to have a small piece cut and the remaining pipe expanded. After that, I got it welded up
oldschool
02-09-2016 09:21 PM
