can the oil pan come out from the bottom?
I have the oil pan bolts off and the motor mount bolts out.... but cannot seem to get the oil pan to drop. I have jacked up the motor to get the tilt but it doesnt seem to help any. What all has
to be pulled to get the oil pan off? Shouldnt I just be able to pull it out with the motor being tilted?
Mike
Mike
I tried doing a search on it and it only pulled up one thing. Didn't really tell how it was done though. Any other ways to do it? Thanks for the info. Spinner! So the flywheel can stay and the torgue converter?
Some cars you can just unbolt the motor mounts raise the engine and unbolt the pan (after you remove the level sensor)
On my car it was a bit too tight to get it out, so I loosened the K members bolts and let the K member down with the bolts out about 2 inches or so. I didnt even have to remove the headers.
looked through my computers history and found the thread i was talking about.. see if it can help you out any.. http://web.camaross.com/forums/showt...hreadid=249010
Well maybe that answered my question. I maybe did not have the motor jacked up far enough. I will try that when i get home today. So the motor has to be jacked up as high as you can get it to go?
-Mike
-Mike
-Mike
-Mike
WS, when you say move it forward and back, is ur forward towards the front of the car or bakc of the car from under it? lol, i have to know cause i am fixing to do it at home.
thanks
mike
thanks
mike
