Can the TPS be cleaned
Re: Can the TPS be cleaned
The sensor is pretty much a sealed unit, with a projecting shaft that engages the throttle shaft and rotates with it. Since its little more than a rheostat, you could remove it from the TB and try and flush it out with electronics contact cleaner. Also check the harness connector for loose wires, or corrosion on the pins. While the sensor is off, connect an ohm meter accross the pins for the blue and black wires, and watch for a smooth change in resistance, with no sudden "blips" to indicate a bad contact spot.
tdigger9899
09-07-2015 11:56 AM
