can u change the front main seal without pulling timing cover?
Old 05-28-2003 | 07:19 PM
Matt97PTA's Avatar
i think my front main is leaking a bit and figured i might be able to just take of the balancer and rig it out some how. Also i was thinken of doing the same thing to the seal on the water pump drive shaft if anyones ever tryed that how did it work??
Old 05-29-2003 | 06:02 AM
Mtrhds94Z's Avatar
Both can be done with the TC on..
The hub has to be removed also[not just the balancer]
Water pump seal is a PITA get 2, and do a search for a few recommended 'techniques'..
Old 05-29-2003 | 06:15 PM
Matt97PTA's Avatar
thanks ill be attempting this tommorow so ill e how it goes.
HectorM52
07-30-2017 11:46 AM
*Emilia*
05-13-2015 09:05 AM
willismoons
02-14-2015 08:42 PM
Gtpguy
01-26-2015 04:50 PM
Queens94z28
12-20-2014 09:11 PM
Quick Reply: can u change the front main seal without pulling timing cover?
