Can you test an O2 sensor?
Re: Can you test an O2 sensor?
If you have access to a scanner, the mV's will change pretty rapidly around 100mV upwards to 900mV's. I beleive they also take 5V, so you could see if you get 5 volts at the connector that plugs into the o2.
Z
Z
jj_burchiel
03-21-2015 12:51 AM
