Can't get the A/C out
I took off the 3 bolts on the front (16mm) and 2 bolts on the back (10mm and 13mm) which happened just to disconnect the lines. The thing wriggles around now but I cant get it out. What do I need to do? All the lines to it are disconnected from it also.
Ya it is the compressor. My bad. Did I get all the bolts and things attaching it? If so now I can start yanking on it. The lines are out of the way since we are installing cam so we got the whole front area out. For some reason is just wiggles a little and that is it. Looks like tomorrow the crow bar is coming out. Thanks.
