Can't get Hooker LT's removed! HELP!
#61
#62
#63
BTW, I called Thermal Tech Coatings, and they seem very knowledgable about coatings. I may actually give them a try. If I do, I will update this thread.
They have a turn around of 7-10 days. What is cool is that they are only 3 hours away from me, so shipping time is 1 day and around $13
#64
doesn't need to be a lt1 head. i'm pretty sure the header will bolt up to any sbc head. if not then it may have to be a d-port head. it's a must or else you could have header flange leaks that you won't be able to get rid of which can blow out your gasket in a matter of a minute. what you may be able to do is bolt it up to your car, tack weld a spot, take it off and then you may be money.
#65
#66
ANY SBC head works, I used an old iron head. It is just to be make sure the flange is on the head surface so it stays flat when welded. Heck, a block of wood would work if you wanted to drill the holes and bolt the headers down on that....
#67
The headers are sitting here in the office floor at work. Everyone is asking about them!
#68
Weld it up as it is and then have it coated. If you coat and then weld you will have a spot there that is going to rust quickly.
I would get a SBC or LT1 head and attach it and have it welded. I just took mine to the local muffler shop and had the header on the head and they welded it up for $5 or nothing, cant remember. I used the head to make sure all was line up right and would not move after welding.
-B
#69
RX Speed Works
07-24-2015 02:25 PM
07-17-2015 02:47 PM
