Cant get y-pipe off...
I'm trying to get my y-pipe off from my stock manifolds so i can install my headers, but i cant get the thing off. It came off from the cat back easy. I took the 3 nuts off each flange where it connects to the manifolds, but the flanges dont move after i've removed the nuts. Is there something i've missed here? I figured that after i removed the nuts that the flanges would come loose and slide off, but they wont budge. Have i missed something? Or are my flanges just stuck? Thanks for any help!
ACA Performance is right, the only thing holding the flanges together is rust. Try hitting the flanges with a hammer. If that doesn't work , try spraying the flanges with WD-40/ PBlaster and then repeat with hammer.
i've used PB Blaster on rusted stuff...much, MUCH better than WD40 (IMHO). it's only a couple bucks from Discount Auto, or some of the other auto parts stores...
if you've got a day or two, spray it once and let it sit overnight...spray again next day.
travis
travis
travis
travis
That is odd, my bolts broke off on the flanges, all of them!! When I got the last one done the Y-pipe almost came down and busted me in the head Good thing there was something in the way stopping it from falling
Alright guys, i finally got it off tonight! It wasnt nothing that a half can of PB Blaster, a pry bar, and a hammer couldnt remove . You guys all say you snapped your bolts and your flange fell off....Well, my bolts came off almost efortless believe it or not! Anyhoo, thanks for all the replies everyone!
