Canton Pan & Windage Trays???
Was talking to a buddy of mine and he was saying that it's not necissary to even run a windage tray with a baffeled pan like a canton pan, cause it's already built in.. Is this true? I asked him what if I left the tray in if it would matter and he said it more than likely won't even fit..
NO it's not a stock windage tray either
Originally posted by Rock_N_Rolla
I'm also interested in this discussion ...TTT
I keep forgetting that the only questions that people can answer in LT1 Tech are "what's the best exhaust and what kinda intake should I get"
No wonder where all the FAST 14 sec f-body's I always see at the track come from
Well I've just spent 3 hours jacking up the motor and dropping the K member ...I get the canton (242t) pan finally up under the block and guess what ...the pan won't clear the Gm windage tray ...arghhhhhhhh. So I guess you're right ...no Gm windage tray. I'm going back out to remove it.
Later.
Later.
Later.
Later.
Anyways, how's that pan look?? I know I heard that they had all kinds of problems back in the day but I guess canton has revised it or some $hit... What's the 411 on that thing?
Originally posted by 97 RedSS
......maybe if you tried a "search" you would find some good info..
Cody
Cody
Well actually cody had some good insight on the Milodan windage tray and the stock pan thanks M8. ...but now I've removed the Gm baffle/windage tray the Canton pan fits up OK. The pan is not a very well made piece I've deburred it etc ...but it's GONNA FIT !!
I'm still under the car 3.00am ..later
WobblySausage
10-07-2015 10:09 AM
