Car bogging and stutering please help!!!!
ok I have a 97 Camaro z28 lt1, following mods are ls1 intake, msd opti and wires, acdelco plugs, 12 bolt rear end, t56 6-speed, ported and polished heads, bigger maf 52mm, bbk throttle body, stage 2 clutch, comp cam 293/313..
now when I drive down the road it stutters a bit until about 2300-2500 then lot of power out of nowhere, and when holding steady speeds it will stumble and jerk a tiny bit until I let of pedel.. and runs fine at wot?
could this be to big of cam? or some sort of vacuum leak or loose plugs?
Re: Car bogging and stutering please help!!!!
Are u sure that is the right cam specs. For a 350 that cam is way oversized. I have the gm847 and I'm pushing it with a 355....
Also you said it works perfect at WOT try the o2 sensors since the computer does not use them at WOT.
Sent from my DROID RAZR HD using Tapatalk 2
Also I'm not to keen about the msd optis they tend to "fall apart" there's nothing like a good lol ac delco
supercharged94Z28
02-24-2003 10:22 PM
