Car Died, Ignition? need help ASAP
#16
Take the red lead of the DVM to the POSITIVE battery termonal and the other to the green wire and crank. You should see it switching from 0 - ground several times... then switch to the black lead on ground and the other lead on the other wire and make sure that you have battery voltage.. lemme know
#17
Found it!!!! Opti Spark!!! The optical sensor was completely corroded. I just had that opti put in at a dealer less than 4000 miles ago. I hate having to take my car to them because of bad experiences there, but I dont have a choice this time. Should be fun getting them to own up tp their mistake. Thanks for all the help guys.
