Car died and won't restart-any ideas?
I just replaced the starter on my SS with a Summit ministarter, and fired it up while it was still on ramps and jackstands. The starter turned it over just fine (I had already checked clearances) and it started almost immediately. I started taking it off the jackstands, and let the car down, and as soon as the back wheels hit the ground it cut off (didn't hit hard). It wouldn't restart (though it turns over fine), and I noticed that the engine sensor fuse under the hood had blown. I put in another one, and it blew again, so I'm thinking this is probably related but I don't see anything obvious wrong. The battery cable and purple wire are attached where they should be, and everything is tight and not touching. I have verified that the fuel pump is coming on. The engine was just swapped in recently, so it could be anything, but does anyone have any ideas?
Are you out of gas? If the engine turns over then it's apparently not the starter. What's left that could have happened when putting it on the ground.
Check spark---might have loosened a ground wire or when suspension engaged boogered something. Get busy and start eliminating possibilities, fuel, spark, etc. JMHO.
Ok, it started, but it took longer this time than usual (almost like happens when a fuel pump relay is bad), and set a code, which I have no ability to check. The fuse popped again, so I have a lot of checking to do...maf wiring, o2s, etc. What a PITA.
I unplugged the MAF while I cranked it, and it still blew the fuse, so I guess its not that. I have had to modify my o2 wiring (the rear o2 wiring is taped up, since I'm OBD1 now, and I had to replace a burned connector), so I'm betting thats where the issue is. For now, I have to get some more fuses before looking any further.
12-04-2014 11:56 AM
