car has a stumble in drive with the brake held
what could be causing it, as it moves with the brake off it is like it is hunting surging?? I did the 383 and will have the pcmforless computer in it soon. Think the O2 sensors are bad? Put a new map in it and cleaned the MAF screen and wires with contact cleaner per PCMforless. What do you guys think?
so run the 30 pound injectors
???? Also I had the new pcm set up and asked if the cat could be gutted and he said yes it could, should I do it, cause I smell rotton egg smell like the cat is working bigtime, motor runs hot sitting still like it cant get the exhaust out fast enough.
12-01-2014 08:08 AM
