Car keeps blowing fuses
Old 12-30-2003 | 02:12 PM
Jerm982's Avatar
Today I scanned my car and found that the Air Pump fuse had blown, I found a 40amp where there should have been a 20, I replaced it with a 20amp and it blew, tried another one, it blew, then tried a 30amp it also blew. What could be causing this? 95 z28. Thanks.
Old 12-30-2003 | 02:24 PM
red 95 z28 lt1's Avatar
a short in the system or an overload on the pump which means its time to replace it(possibly a loose wire)
Old 12-30-2003 | 02:32 PM
PGR's Avatar
PGR
Your air pump is most likely shot. They trap moisture and eventually corrode from the inside.
Carefully unplug the connector at the air pump and see if it still blows the fuse. If is does, you have a short somewhere in the wiring to the air pump. If it doesn't, the air pump itself is most likely shot. Remove it, disassemble, and you'll see.
Mine finally died last year, on my '94 with 170k miles.
DamianLT1's Avatar
Those are never easy to find. Good Luck but yeah you have a short somewhere.
Old 12-30-2003 | 07:57 PM
Jason Dove's Avatar
Have you done the air pump recall? If not, now is the time to do it.
Old 12-30-2003 | 11:48 PM
RENE95Z's Avatar
I ran into the same problem. I did what was suggested above and removed the pump and took it apart and voila, moisture built up and killed the pump. Just for giggles, check your MAF screen for any debris that might have come out of the pump. Mine was coated with some spongelike stuff that was on the inside of the pump.
Old 06-12-2005 | 01:23 PM
Kevin_315's Avatar
Re: Car keeps blowing fuses
was this recall only on the 94 and 95 's or also 96 97
Britbilly
01-07-2015 08:49 PM
ModdedNerd
12-25-2014 05:51 PM
fpete1992
12-11-2014 03:51 PM
USAirman93
11-24-2014 03:37 PM
$hawn
08-17-2002 04:37 PM
Quick Reply: Car keeps blowing fuses
