Car Making Noise When Turning Left
Hey everybody, I just notice my car when turning left it makes this noise which sounds like when your brake pads needs to be changed. Also the sound appears sometimes when I am just driving normally. The noise is more noticeable and is a little bit louder when turning left. But when turning right no noise. I was wondering if anybody would be able to give me any suggestions or ideas on what I should check. Thanks in advance for your help.
Check you motor mounts. I had a similar problem ended up being that my left mount was so shot that the head of the bolt was rubbing on the head of another bolt making a very noticable clicking sound when braking or turning left.
Hey everybody, sorry for the delay in replying sooner but 2 weeks ago, I put my car on jacks and pulled off my front driver side tire and found out the little indicator on the brake pad in which it tells you that you need to change your brake pads, was touching the rotor. So I went ahead and bought a pair of front rotors and pads. After installing the pads and rotors, I took the car for a test drive and there was no noise at all. I was so glad it was the pads and not anything else. So before buying anything, check your brake pads first and go from there. If you have any questions please feel free to e-mail me. Thanks.
THANK YOU SOOOO MUCH
tHANKS SOOOO MUCH FOR GIVING US AN UPDATE!!! I definitely was in need of the information as I developed this noise just last week. Well seems this weekend I will change the pads and rotors along with te shocks, balljoints, tie-rod ends....hahaha Seems like I have a weekend planned.
to snk94 i think my problem might be the motor mount. its a pretty loud clicking noise when turning the wheel and braking sometimes its a loud click. does anyone know what it might be, doesnt do ti while drivin only while going slow or slowind down to a stop, put new pads and rotors on about 10k ago so dont thiink thats it. plus it did it b4. i hate it i hope nothing majjor is wrong ima try to get it checked out. if anyone can help please do!
NewsBot
12-03-2014 12:30 PM
