Car rumbles and almost starts, but doesnt.
Hey guys, still learning alot about the Lt1 so go easy on me, and as always, THANKS for reading.
My car:
'93 Z28 5.7L Camaro with 36,442 miles on it. It has a new battery, and the only mod is a Magnaflow exhaust after the catalyst converter (which has been running smooth since I did it two months ago.)
Ok, it seemed like this week the car wasn't putting out as much power as it normally did, but I was hoping it was my imagination. I have no numbers behind this but it felt more like I was driving an S10 when I put on the gas than Z28.
Thats just background. Today, I went to start the car and the ignition kicks in and it starts to rumble but then doesnt "catch" and the car dies (if die is the correct term). I think the battery is fine, because all the lights, stereo, ect, work when the car is off.
I wish I had more info to give you all but I am a noob.
Thanks so much for reading this, and your help. Please save me =(
My car:
Re: Car rumbles and almost starts, but doesnt.
Scan the ECM for codes. It's easy on your 93. Just short the ALDL pins and count the flashed on the SES light.
http://shbox.com/1/dlc2.jpg
Then look them up on this chart - note 93 is a separate column:
http://shbox.com/1/Dtcs.htm
Check out Shoebox's Tech Pages.... lots of help there.
http://shbox.com/1/4th_gen_tech1.html
I feel like an idiot, but after sitting in the car for two hours counting flashes I though I would ask:
How exactly do I count them? The "Service Engine Soon" light comes on just like the tutorial describes: Flash, pause, flash flash, long pause -- and keeps going.
I counted that sequence as one flash, and gave up at 200 (seeing how the chart only goes up to 99 I figured that was safe)
What am I doing wrong.
Oh, and I just learned I can get the car to start if I feed it gas while turning the ignition, if that points you in a direction.
Thanks for your help thus far!
lol, no.
Ive been using the stock intake system with a brand new K&N filter. Just today (after this whole mess) I took out the stock box and stuck a Cyndrilical K&N on the intake elbow.
