Car is running bad once it warms up. Need Help!
Old 06-03-2006, 10:17 PM
  #31
Eck
Eck's Avatar
Re: Car is running bad once it warms up. Need Help!
I'm having this same sort of issue right now. I scanned my car and my right O2 wasn't getting any voltage so I swapped it out with a brand new one. It still did the same thing. My opti has gone bad before and these are all symptoms of it. I think my opti shat itself again. I'm finding out for sure this week while I'm getting my cam installed.
Eck is offline
Old 06-04-2006, 09:53 AM
  #32
94_PatriotRed_Z's Avatar
Check your o2 wires maybe you burned one up on those headers
94_PatriotRed_Z is offline
Old 06-07-2006, 09:23 PM
  #33
Vigilante's Avatar
Took the car to another mechanic. He assured me that it was ignition related and not a fuel problem, but he couldn't figure out what was wrong. Maybe I'll try someone else next week.
Vigilante is offline
Old 06-07-2006, 09:27 PM
  #34
nodnarb481's Avatar
try the ICM cooling mod on shoebox's website. I have this problem and will be trying that sometime next week when i get time. Apparently it shows phenominal results, assuming the ICM is the problem.
nodnarb481 is offline
Old 06-30-2006, 04:57 PM
  #35
97BBlackZ's Avatar
So has anyone fixed their problem yet either?
97BBlackZ is offline
Old 07-06-2006, 01:00 PM
  #36
WinkleTheMoose's Avatar
I'm having the same problems and I have tried all of those methods and it still doesn't help. If I let my car sit for an hour after doing it, the car will run fine. So i guess now I'm going to try my MAF and see if that helps. Otherwise, there is nothing else to try.
WinkleTheMoose is offline
Old 07-10-2006, 01:01 AM
  #37
Vigilante's Avatar
Nope. Believe me, I'll let you guys know when it's fixed.
Old 07-10-2006, 01:02 AM
  #38
Found out my fuel pump was bad. Its something to check into.
Old 07-11-2006, 05:53 AM
  #39
Guest
Guest47904's Avatar
All y'all need to check the frequency response of the MAF. Simple 2 minute test with a multimeter that reads frequency. Measure frequency at the yellow wire to ground with engine running. Snap the throttle and see if the response jumps over 7KHz. If not clean and try again. If still lower, replace it.
Unplugging will not always find the problem with the MAF but the test will.
Guest47904 is offline
Old 07-11-2006, 11:23 AM
  #40
Hark_z's Avatar
My car all the same symptoms as above, longer it heats up the worse it gets with the fuel cutting off until it is pretty much impossible to drive..
The opti is going to be replaced so I'll let you all know if that's the problem.
Hark_z is offline
Old 07-11-2006, 11:28 AM
  #41
KPZ-28's Avatar
When doing the maf test that speedy suggests, I get 3 khz at cold idle and when I snap the thottle it goes to only 5 khz. Would this be normal since my maf is descreened? Also would using a paperclip pushed thru the weatherpak connector on the yellow wire give an accurate reading since my reading was low or what is a better way to do it?
When I get a missfire when warm, unplugging the maf changes nothing.
KPZ-28 is offline
Old 07-11-2006, 12:23 PM
  #42
Its the fuel pump. I just replaced mine, and every probem dissappeared.
Old 07-11-2006, 04:29 PM
  #43
97BBlackZ's Avatar
I replaced mine and still had all my problem
Old 07-16-2006, 01:08 AM
  #44
KPZ-28's Avatar
I have the same problems as 97BBlackZ, I first replaced fuel pump,fuel filter, plugs, wires, intake elbow w\ new iat, coil, icm, ect sensor, and finally replaced opti and waterpump. The new opti fixed the problem and it ran great in the recent 95 degree heat. I install a moroso cold air intake today and in 10 minutes my car starts to missfire and stall. I scanned it and it has po171 and 174 codes. I put the stock airbox back on but it still runs like crap. Has anyone fixed this yet? I thought I solved it till I put on my new cai.
KPZ-28 is offline
Old 07-16-2006, 01:10 AM
  #45
Help this guy out, he has been struggling with this car for a while.
Did you check the Fuel Pressure to see what it is doing? should be at 45psi if it is a strong pump.
Quick Reply: Car is running bad once it warms up. Need Help!
