car wont idle
car wont idle
wierd problems with this car
starst up fine idles for about 1 sec. then dies
if i sit and give it throttle it will idle and sometimes after i force it to idle for a little while it will do it by itself
i am stumped i think the iac may be screwed
i checked for air leaks and i dont see or hear any
![Thumbs up](https://www.camaroz28.com/forums/images/icons/icon14.gif)
check you cold air intake and make sure its all on tight and all your wires are pluged in and check to see that your maf and all that have all the propper connections if this doesnt work unhook the batter for 10 min and try it then sometimes its something stupid and the computer will fix its self!
I am having the exact same problem on my 93 Z28. An answer would help.
So far I have been told to check the engine for vacuum leaks, and then check the plugs.
The plugs in my car are fairly new, and the car doesn't appear to have any vacuum leaks....So I'm stumped on this
![Confused](https://www.camaroz28.com/forums/images/smilies/confused.gif)
Originally posted by lt1camaroman93
i had the same problem on my 93. would start up but then die.. if i gave it gas it would stay running, but backfiring, and real rich, woudln't idle no matter what.. endded up being my icm.
Originally posted by Kris93/95Z28
Where is it? How do I test for it being bad, etc? Cost to buy a new one.
Sorry I haven't ever ever heard of this thing
![Wink](https://www.camaroz28.com/forums/images/smilies/wink.gif)
The 1993 version screws in, instead of having the hold down bolts.
Testing the IAC, itself.
Shoebox: Do you think I should pull the intake elbow and spray some intake/carb cleaner on it to see if that helps?
$140? Nah, not even at dealer list price. Dealer wholesale is ~$50. You can also get one from your local auto supply.
ICM
Your Ignition Control Module is located on and directly above your coil. It is small, somewhat rectangular, and has four wires that connect to it. Your problem sounds very similar to one I had. Get your Haynes, a voltmeter w/ various functions (like reading resistance, volts, etc) and start diagnosing. Just follow the flow chart. I've had my ICM go out twice in the last year. Could be a coincidence, but I'm waiting for a third time and I'll look for a cause for blowing my ICM. I had a bad experince with a knock off brand ICM, so I recommend buying the GM one - about $140 I think.
