Car Won't Stay Running !!!
Old 10-08-2011, 01:40 AM
  #16
Fatdog2's Avatar
Re: Car Won't Stay Running !!!
Maybe you o2 sensors are not getting hot enough to send info to the computer.read this somewhere.Might do a search.Hope this helps.(o2 heaters?).
Fatdog2 is offline
Old 10-08-2011, 08:31 AM
  #17
raroz28's Avatar
Doubt it.
You can unplug the o2's and the car will still run.
Since it's doing it all the time, I would recommend checking the fuel pressure. Get a cheap harbor freight gauge and connect it to the schrader valve on the back of the intake.
Report back with your results. You should be at about 43 PSI.
raroz28 is offline
Old 10-08-2011, 10:03 AM
  #18
Pullngz's Avatar
How did the car run BEFORE, the exhaust and opti/wires were installed?
Pullngz is offline
Old 01-14-2012, 05:07 PM
  #19
Smith.justin51's Avatar
Any luck fixing it? My cars doing the same thing.
Smith.justin51 is offline
Old 06-26-2015, 05:19 AM
  #20
weigh2fast4u's Avatar
BUMP PLease. My car gets warm and just SHUTS off. no stubbling or any warning. like i reach up there and Turn the key off..... Ive changed three fuel pumps, and the ICM. summit is bringing me a new MSD coil today.... Ive been scratching my head for over a week now.
weigh2fast4u is offline
Old 06-26-2015, 07:17 AM
  #21
At any point have you scanned if for codes?
You need to add info to your signature... like year of the car.
Injuneer is offline
Old 06-26-2015, 07:20 AM
  #22
I haven't. will it throw a code without a light coming on?
Old 06-26-2015, 07:29 AM
  #23
How much voltage should be at the wires going into the fuel tank? I can't find that on shbox
Old 06-26-2015, 08:24 AM
  #24
If you mean to power the fuel pump, it's 12v. Yes, it is on shbox.
shoebox is offline
Old 06-26-2015, 08:51 AM
  #25
Unplugged opti harness. Purple and white wire terminal was corroded. High resolution. hopefully it will run now thanks to some vinegar. we will see
Old 06-26-2015, 10:38 AM
  #26
Yas.
DTC 16, for loss of low resolution pulse signal from the cam position sensor in the Opti, does NOT turn on the SES light, but it shuts down the fuel system (pump and injectors).
Injuneer is offline
97SSdude
12-31-2014 07:43 PM
USAirman93
11-24-2014 03:37 PM
F(ast)-body
02-26-2003 09:05 AM
supercharged94Z28
02-24-2003 10:22 PM
MJ_Z28
08-07-2002 07:15 PM
Quick Reply: Car Won't Stay Running !!!
