catalytic converter
catalytic converter
Hey guys, gonna get a y-pipe welded up for my jet hots...i have the hooker y-pipe and i was going to get the cat welded in in the section right in front of the cat-back system...will the cat work all the way back there or should it be closer to the headers?
Location: brunswick ohio, small burb south of cleveland
no information to base this on but i dont think it would matter. all the air has to go through it at one point or another. is there some shielding under the car that might make one spot better than another?? maybe some air flow engineer type can say better where to put it.
If you have emissions testing where you live, moving the CAT(s) from from its original location would be a violation. The farther back you move it, the less effective it is as the exhaust cools as it moves through the system and CAT's need to reach a certain temp to be effective.
-Tony
-Tony
NewsBot
09-14-2015 02:02 AM
GusarskiSS
Exhaust System
09-02-2015 03:51 PM
