catalytic converter on pacesetter y pipes
i was wondering if anyone has had cats put on pacesetter y pipes and if they had photos, and which cats to use, and where on the ypipe did you weld them. the car is a 97 z28 with lt1
Heres some pics of my catted y with Pacesetter's. These are Magnaflow 3" cats. Keep in mind I have a Spohn chasis mount trq arm which gives a bit more room for the driver side cat. I also bent the fuel lines straight across as you can see in the one pic. When bending the lines just becareful not to kink them. I also have an off road y and I run the same mph at the track so I'm pretty sure its not costing much power. I have never dynoed with and without but track perfomance speaks for its self. Passed the sniffer test in Ontario too
drptop70ss
05-04-2015 08:22 PM
racecarz28
03-30-2015 09:55 PM
