CAUTION!! About Hotcam and Heads
#61
Re: CAUTION!! About Hotcam and Heads
Originally Posted by WSChris
Well Aaron I Guess You Were Right About Catching A Lot Of Crap From The Guys By Posting While Pissed! I Do Believe There Is A Lot Of Experience On This Board And It Seems Like Most Of The Guys Have Good Input/advice When You Need It. We've All Had Our Share Of Problems, Thats Usually How We Learn. And Face It, With This Hobby There Are A Lot That Can Go Wrong No Matter How Careful You Are! Sorry About The Bad Luck, Hopefully Whitewater Rafting In A Few Weeks Will Go Betterfor You! I Know I Hope So Since We're Going With! When It Comes Time For The Rebuild Let Me Know And Ill Help You Out Instead Of Jay (who Might Be A Nice Guy But I Dont Trust) Chris
#62
nah, i think i had the caps lock on. i wonder why it wasn't all in caps? maybe we just found out what happens when you reply to a post under those conditions...
#63
Originally Posted by WS Sick
I also allways leave shop rags in the intake ports of the heads. It allways makes a nice little spark and flame like sparkler show out the exhaust on start-up. Sometimes I'll run a 1/2 cup of sand in with my oil for good measure
#64
Is there a difference between an SBC pickup and pan and the LT1s? I had a CC305 installed for about 2 weeks before it spun a bearing, and I was meticulous in keeping everything clean. I did not, however, drop the pan. I just got a new used motor and put in a bigger cam. This time I dropped the pan and put on a new oil pump with a white spring. If this one goes anytime soon due to a bearing failure, I'm parting it out. Too much time and money for far too many frustrations. I don't buy into the core-shift idea, cause I never had the heads off, don't think it was debris, because I was meticulous and the motor was in immaculate condition. I would expect these cars to handle 6800 rpm on a stock rotating assembly, and maybe thats the issue. Would having a bit too much oil help at all? I would be willing to sacrifice a bit of power to windage if it ensures some better reliability.
#65
i have to wonder about the coolant in the oil
when my head gasket went south more than half the coolant went
into the oil pan, i even refilled the radiator to make sure of the problem
and it ran out as quick as it went in , and the car sat for about two weeks
and after i repaired it i never had a problem with a spun bearing.
maybe it was the castro gtx oil?
#66
Did the blown headgasket blow between cylenders, to the lifter valey , or into a coolant passage?
The first two can be driven around for quite a while with nothing but a little extra tick noise and a loss of power as the key, the last would be alot more noticeable. Usually coolant into the oil making it milky and or water out the exhaust.
#68
Originally Posted by Smokn '94 Z
Well I too must be one of the good, unexpierienced, lucky head and cam swap guys... I am lucky I guess.
she runs good so far
steve
#69
dont drive your car you will spin a bearing or throw a rod, or some one will hit you, anything can happen heck i threw a rod with 60k on the clock!!
my guess is going to go toward something getting down there!! you siad it was down for 4 weeks, that leaves plenty of opportunity for something to oopsy!!
#70
Hot cam and ported heads about 3,500 miles ago, no problems yet. 91,500 miles on car. I have made 20-30 trips down the track too. Have had several other problems like opti, wires and plugs.
#71
Well, since the error has been pointed out and this has become a show of hands I'll throw my experience in as well.
I've gone through a couple of cams already and am gearing up for another cam swap... my setup is always changing I've also had the heads off and when I get the time they'll be coming off again. I've ran my stock shortblock up to 6500 RPM on many occassions. So far she's still holding together.
I don't know of any spun bearings from all the local cam swaps either, I've even helped on some
I too believe that it's contamination that causes this problem. A lot of people have done some pretty crazy things. For example, using sandpaper to clean the gasket surfaces You shouldn't even use the abrasive pads to do such a thing!
#72
Originally Posted by FastZinTennessee
Coolant in the oil and white smoke. Actually, after a while it was only water in the oil- It kept using coolant so fast, and I kept adding it, so the coolant was clear instead of green
Wilson
07-21-2002 05:08 PM
