cc 306 engines done and cars running great...any predictions?
Old 07-31-2006, 12:49 PM
  #16
1SlowFormula's Avatar
Re: cc 306 engines done and cars running great...any predictions?
Originally Posted by ssean92
what is that website bro, i am not familiar with it. thanks
here is Brent's homepage not sure where the .bin is but it shouldn't be too hard to find.
http://www.bfranker.badz28.com/
1SlowFormula is offline
Old 07-31-2006, 12:53 PM
  #17
ssean92's Avatar
thanks alot
ssean92 is offline
Old 07-31-2006, 01:23 PM
  #18
ssean92's Avatar
man i looked on that site and nothing
ssean92 is offline
Old 08-01-2006, 10:46 AM
  #19
ssean92's Avatar
what springs you guys using with this cam????
ssean92 is offline
Old 08-03-2006, 11:53 PM
  #20
Wckd94Z's Avatar
918 beehives
Wckd94Z is offline
Old 08-04-2006, 02:03 AM
  #21
Critter's Avatar
behives you might get into some valve float, i'll try to get a part number on what i'm running.
Critter is offline
Old 08-04-2006, 06:30 AM
  #22
ssean92's Avatar
from what i have seen the ones that cc calls for are 295 lbs, and the lt4 hot cam springs ate 310 so i think the lt4 onse should work right, and also if some one can help me out with the bin file that would be cool, i just want a place to start
ssean92 is offline
Old 08-04-2006, 09:33 AM
  #23
blkchevyz's Avatar
dont think the lt4 springs will handle the lift
blkchevyz is offline
Old 08-04-2006, 11:52 AM
  #24
chevy1963's Avatar
Your right the lt4 hotcam springs will not handle the 306 lift height. I think I'm running cc 987 springs, " i think thats the number" I had LE do my heads
chevy1963 is offline
Old 08-04-2006, 12:13 PM
  #25
ssean92's Avatar
i dont see why not seeing that the lbs per inch is higher then what they say the 306 cam needs, i am confused. 295lbs for the cc springs cant remember the # and 310 lbs for the lt4 hot cam, abd if you compare the two thre inst that much lift diff just duratiion
ssean92 is offline
Old 08-04-2006, 12:25 PM
  #26
blown94's Avatar
The lt4 hotcam springs are only good to like .525 lift or something lame. They wont handle the lift #'s of a cc306 with 1.6 rockers. Can you say COILBIND.
blown94 is offline
Old 08-04-2006, 12:27 PM
  #27
ssean92's Avatar
cool i will look for some others thanks guys
ssean92 is offline
Old 08-04-2006, 12:30 PM
  #28
blkchevyz's Avatar
the 306 is somewhere in the 570 lift range once you throw the 1.6 rocker arms on it. thats will put the lt4 springs into coil bind.
Old 08-05-2006, 08:49 AM
  #29
Critter's Avatar
i think its 576 so the lt4 springs won't be springs for very long. more like pieces of metal
Critter is offline
Old 08-05-2006, 01:40 PM
  #30
zx1216's Avatar
I talked to a few people and the 918 beehives are what i went with with my cc306. I haven't dynoed it yet but they don't seam to float all the way up to 6800 with the steel retainers. Car ran 12.424@114.09mph with a crappy 1.993 60' on stock heads and a full weight car without the front swaybar and jack/spair. The spec III was also toasted after i came back from the track so i think the car has 11's in it if i can hook it.
zx1216 is offline
Quick Reply: cc 306 engines done and cars running great...any predictions?
