CC 503 224/230 OBDll misfire?
so i recently installed the 224/230 cam
about a week or so later i started getting a random misfire code
the cam is still untuned
would this be the infamous OBDll misfire with a cam , this cam is not really that extreme so im wondering if this could be it
the car goes through the rpms with no problems, its actually pretty smooth ,
it sometime has an off idle studder especially when cold but goes away and timing marks were set correctly even on t he opti/dowel,prolly untuned cam?
rockers are set but will be checked again
i did a search and madwolf has mention a more radical than stock cam can set of misfire codes especially on OBDll cars
im looking for some more updated info and reassureance
thanks guys, hopefully buy the end of the day i can get u the exact codes
thanks
bobbyd
thanks
bobbyd
Re: CC 503 224/230 OBDll misfire?
I have that cam in my 383, and ran it (untuned) OBDII for a few months before getting the tuned OBDI conversion and larger injectors.
While I ran OBDII, not once did I experience a missfire code that wasn't due to a burnt plug wire.
i have similar problems w/ mine but i have the 502 grind. changed everything plugs, wires, ect. still can't figure it out.I also thinking it might be that i need a tune really bad.
Originally Posted by MeanGreen97Z
I got the same thing from the hotcam. No worries. Get it tuned.
the only thing i can think of is that its the idle b/c of the auto
autos wil idle lower than manuals , around 650 for autos and closer to 800+ for manuals so the idle difference causes the cam to lope and make the computer think theres a misfire
thanks for teh help guys , hopefully the tune works great
zajones
07-30-2015 02:18 PM
