CC Pro Mag RR
#17
Originally posted by AdamZ1LE28
Well do the Comp Cams Pro Magnum rockers need guide plates or not? I still can't find the answer out there. Someone in here must have them, and did they use guideplates?
The ones I'm looking at are PN# CCa-1302-16 at summitracing.com
http://www.compcams.com/Technical/Pr.../ProMagnum.asp
1302's are NSA for 3/8" (stock diameter) studs
#18
The part number you gave me is for a 6 cylinder.....
#19
It has nothing to do w/ brand name, it has everything to do w/ the rockers being nonself-aligning or self-aligning! The Pro Mag rockers come in self-aligning (SA) AND nonself-aligning (NSA), AND 3/8" AND 7/16"stud length. IF you select NSA, you need to get guideplates (GM preferred-and the pn I gave in a previous post, along w/ the one Shoebox posted, is correct). If you select SA rockers, you do NOT need (or want) guideplates. Contact the folks at Combination Motorsports; they will be most helpful in assisting you to build the power car you're seeking w/ the best results for your $$$.
Your question is a good one. I would suggest a search as there is alot of really good info on this topic which will answer this question as well as questions yet to come. I hope this helps!
