CC305 Dyno Numbers
CC305 Dyno Numbers
I dynoed the car today. It rolled 335.5 rwhp and 346.68 rwtq. This was with the cut-out open. The A/F Ratio was around 12.8, with the car leaning out around13.2 from 5700 rpm around 6600. Not too shabby, but I was really hoping for 340. This is on 100% stock tuning...but given the a/f ratio was so good, there probably isn't much room for improvement - maybe a few degrees of timing would give a few hp. The graph is below.
http://www.public.asu.edu/~dbump/dyno.JPG
Originally posted by Quickshotkimber
Good #s. Have you done any headwork yet?
his sig says stock heads, and considering the dyno numbers, im guessing theyre still stock.
good numbers tho for that cam.
Originally posted by 95 Silver TA
Numbers look pretty good for stock tuning and stock heads. I could not see the graph to clearly, ar what rpms did the cam start to fall of at?
Thanks,
Claude
Thanks,
Claude
Nice #s for stock heads and programming.
I was suprised when I read this that you got that much for stock heads AND tunning. I thought you had atleast some tune on there. Do you have any new track times yet?
Re: CC305 Dyno Numbers
Man, i got the below numbers w/cc305 new valvetrain, long tubes, homemade cold air intake and i dont recall if the cutout was open or not.. also had some tuning. I think i need more tuning cause i'm running rich and I know that's not helping me at all.
I would also say change your fuel filter if you haven't in a while.
