cc306 with Crane kit 10308-1
Starting to get parts together for the cam swap and also trying to keep the cost down. Will the Crane spring kit work with a cc306 cam? Also, will these springs fit right on my stock heads without having to pull them off?
Also thinking about proform 1.6 RRs.
In summary for my weekend warrior:
cc306
crane spring kit 10308
proform 1.6 NSA rockers
GMPP guide plates
Summit chromeoly pushrods
stock lifters (cleaned and functioning)
new GM opti
CM gasket set
Anyone have a mixed bag of parts running in their LT1?
Gonna try to do this at or around a grand.
cc306
GMPP guide plates
new GM opti
CM gasket set
cc306
GMPP guide plates
new GM opti
CM gasket set
cc306
GMPP guide plates
new GM opti
CM gasket set
Yes a new timing chain and eventually a stall. The question is can the Crane spring kit handle a cc306 and do they go in without machining. Any one running proforms with success with a higher lift cam?
Yes the crane spring kit will work. I was thinking about going with it since it was alot cheaper than the 918's. I did a little research and the comp cam 918's are better springs, their lighter and can handle the high RPM's better. Their was an article in chevy hp and they swaped to the behive springs. They gained hp and moved their usable power band up. Made a big difference.
Camaro SS #1039 M6
__________________________________________________ ______________
Full bolt-on, cc306 1.6 RR, 4:10's, no emissions, Elibach springs, Bilstein shocks, BFG/KDW, Chrome Zr-1's.
Camaro SS #1039 M6
Come on guys, are you telling me the car will not perform because I don't have a stall. I will get a stall when I rebuild my transmission which will be later. I'm sure to get everything out of the cc306 a stall is necessary, but it is not crucial to perform.
Black 97 SS
So the beehives made a HP difference, interesting. But will they go in stock heads without machining?
Black 97 SS
Black 97 SS
Black 97 SS
It won't run for **** with the stock stall and a 306. You will be ALOT faster with a stall and a stock cam that a 306 and stock converter.
