CC306 ground wrong?
CC306 ground wrong?
The cam is a Comp Cams 290HR-12 (CC306). The camcard shows the cam to be a 108 C/L. Shows intake valve opening at 37 degrees BTDC. Degreed the cam several times with same results. The cam comes in at 107.5 C/L but the intake valve opens at 48 degrees BTDC, obviously 11 degrees early. Anyone else ever run into this situation?
Re: CC306 ground wrong?
autoxr166
09-25-2015 04:21 PM
