cc306 or hot cam whats the better cam????
I currently have the lt4 hot cam. But I'm wishing I should have gone with the cc306. Is the cc306 sound more aggressive then the hot cam and also does it make a notiable difference then the hot cam??? I have stock heads. How much more rear wheel power should I make over the hot cam on stock heads
I wouldnt recomend a cam that big without heads to flow what its capable of. Im sure there are a few that would work better than the hot cam, but Im going for the 306 with heads so I wouldnt know.
The HOTcam is nice because I noticed little/no loss in low end power on my car, and that's even with ported heads.
Like has been said, if you want some more power, do the CC306, but save up some money and do heads at the same time.
10-31-2016 11:09 AM
