cc306 orcc503
cc306 orcc503
i know im gonna open a whole world of crap for this but what would be better for a cam in my car new ported aluminum heads ported intake longtubes 1.6 rr's and a 2800 stall with 3.23;s gears the cc306 or the cc503 mostly a weekend car with street use and strip
you could get away with either, depends how radical you want it. id personally suggest the 503, since u have a rather small stall. u might want to upgrade to a 3500 or so, do the 306 and some 3.73s then youd be flying
i may go with a bigger gear butt i may go diff rearend before hand as the 10 bolt blows i also have 1 free stall adjustment if i need it also.....i know the lope dont matter but i kinda want one and i like the 306 whats the 503 sound like any clips or anything...if there is im all over it like a bum on a bologna sanwich
I have the 503 and it has a very nice idle. Going to a bigger cam isn't always the best idea. You may get a little more peak power by using the 306, but you will need to rev the engine very high to ever see it. I would put a lot of thought into how you will be driving the car and what you want out of it before selecting a cam.
unless you are willing to spin the cc306 up to 6500+ and have headers you will be wasting your time with it. and when you start spinning that high you have to worry about your rotating assembly.
you know, the cc503 and CC306 aren't the only cams out there.... just the most talked about. Sounds like your looking for a mild cam there are allot of variations out there that you should search around and look at first.
i know not the only cams out there but they have worked the best for me in the past had 2 lunati blow lobes off and 1 crane snap i just like the power ranges of both and witch one will like the spray better.....oh yeah and i like the lope of the 306 i know lope dont mean anything and if that was all it was about id do a hotcam but id like suttin up top with a lope
