View Poll Results: Which Cam?
CC306
15
38.46%
XE227
7.69%
XE230
19
48.72%
Other (please explain)
5.13%
Voters: 39. You may not vote on this poll
Cc306/xe227/xe230
#32
Originally posted by NiteRider
Well said, very streetable, very torquey specialy with stock heads and the cam keeps it's TQ curve flat and fat! From 3500 rpm to about 4900 rpm i'm doing 343 to 344 rw tq. Power everywhere indeed!
#34
Originally posted by chasmanz28
niterider i noticed your running the 230/236 cam on stock heads, how did it effect your gas mileage, and would the stock lifters and pushrods hold up?
#35
Obviously mileage got a little worse, but nothing that would make me complain, I am running 94-octane gas of course. As for lifters I’d say with a cam that has such a aggressive lobe pattern I’d change the lifters, pushrods I bought new stock hardened ones just because everything else in the valvtrain was being changed. This winter those stock heads are coming off.
but i've never heard of anywhere only offering 94.
#36
I believe the owners manual actually says 92 is the recomended. All that is in AZ is 91 at the pump though. unless you want 100 or 106 :P
#37
Re: Cc306/xe227/xe230
Originally posted by MaddHatter
I'm looking for a 11sec N/A daily driven sleeper... LT4 Heads ported, JH LT's, 3.73s, stall, Musser CAI, and a few other misc mods will also be going in. I don't mind lope, I actually like it as long as it's nothing hardcore. I also love Torque over HP... I'm looking to pull 1.3-1.5 60's with enough time behind the wheel.
Neither of those cams would be a sleeper, even a 114 you can tell its cammed. If you want a sleeper, 116 or 117 lobe seperation would idle like stock.
Also, you won't be able to pull 1.3-1.5 60's. Maybe a 1.59 if your really lucky.
But a 11 second car is possible with an auto. With stock heads and a cam I ran 12.2's spinning slightly to 1.65-1.68 60's. With ported stock heads, you'll hit high 11's no problem.
#38
Re: Re: Cc306/xe227/xe230
I don't see 1.3s-1.5s being a problem on slicks with a stall converter and 3.73s pulling the kinda torque I want.
#43
Email it to me at austin@macrecruiters.com
#44
I have a 228/236 Bullet cam and have run the times in the sig.
MaddHatter, you must not do a whole lot of drag racing, because if you did you would know that there is no way you're going to see a 1.3-1.4 60ft in a heavyass camaro with only 3.73 gears and 350 cid no matter what cam you put in it. Now if you put some 4.11's, slicks, and about a 200 shot you may get in the 1.3's.
Randy
Randy
#45
Randy
Randy
