changing clutch fluid
i have an M6 and i want to change the clutch fluid. i have replaced the factory clutch with a borg warner clutch. what type of fluid does this take? also, how would i go about and bleed the line? is there a bleeder skrew and then i need to pump it out? any assistance would be appreciated. thanks
the fluid is just old so i figured i would change it if i could figure out the correct procedure. yeah i did not think i would notice a difference but i like to keep up on these type of things.
You would be better off replacing the whole assembly with a new one from GM. I comes with a slave cylinder, master cylinder, resevoir, and the lines all assembled and pre-bled. All you have to do is take your old one out and put this one in.
