Charcoal Canister Removal
Old 10-16-2003 | 01:02 PM
HectorM52's Avatar
What are the steps involved to remove this? Is this correct?
1- Remove plastic/rubber lines from Intake
2- Remove Line from Intake to Canister
3- Remove Canister
4- Program Out the Purge (is this part of the program??)
5- Remove All Associated Accessories & Wiring
6- Cap Off Intake Ports (Do I need to do this??)
Should I do this? I know about the gas smell, I just want a cleaner looking engine compartment. Has anyone ever done this?
Old 10-16-2003 | 04:36 PM
HectorM52's Avatar
Has no one removed this?
Old 10-16-2003 | 05:01 PM
Black_Z28's Avatar
What is it??? Are you talking about the EGR?
Old 10-16-2003 | 05:14 PM
If you just want to clean up the engine compartment, you don't have to remove the charcoal canister (since it is located behind the LR wheel).
Old 10-16-2003 | 05:17 PM
HectorM52's Avatar
In fact, there are several tubes and electrical devices that are connected with the charcoal canister. Upon removal, there would be less in the "eye-sore" category with all that crap there...
Now, has anyone actually done this?
Old 10-16-2003 | 05:23 PM
94-3.4's Avatar
Does removing just the solenoid and lines throw any codes or cause any unforseen problems?
Old 10-16-2003 | 05:42 PM
Yes the computer will throw a diagnostic code and you will have to deal with the fuel smell, because fumes from the gas tank will have nowhere to go.
Old 10-16-2003 | 07:13 PM
HectorM52's Avatar
So can you program that out? Meaning can I delete the part that would throw a code if I took the canister off?
Old 10-16-2003 | 10:12 PM
The EVAP code can be programmed out.
Old 10-17-2003 | 06:57 AM
HectorM52's Avatar
Thanks!!
94Z28LS1toLT1
10-04-2015 11:28 PM
GusarskiSS
Exhaust System
09-02-2015 03:51 PM
350350
14
08-11-2015 12:03 PM
Alibi
08-01-2015 07:50 PM
Quick Reply: Charcoal Canister Removal
