Chatter from around plug 8? help me!!! IS IT DYING???
i know i have an exhaust leak on the passenger side. today i started the car up and was under hood. i reved it a little from the tb to listen to the exhaust leak.... then i hear a chatter when it reved down from around plug 8. only when it reved down from higher rpm ...(around 3000 i would guess) almost sounded like a diesel idle type chatter.
1. exhaust leak (possible crack in manifold?)
2. lifters? rocker arms
3. something internal? (maybe rist pin?)
keep in mind i have 188,000 miles
i know i need to rebuild regardless... just don't have that kinda $$$. shot me some theorys plz.
Re: Chatter from around plug 8? help me!!! IS IT DYING???
A compression check will settle most mechanical issues. The plug should let you know if you're getting fuel & spark. If it seems ok, it's possible you could have an exhaust leak. It also wouldn't be a bad idea to get a piece of hose and listen around under the hood. A lot of noises can be deceiving down there.
charchri4
04-14-2015 06:40 PM
grabbem88
03-18-2015 01:25 PM
