cheapest springs for 306 cam
Re: cheapest springs for 306 cam
Here is the info with part number for the spring that I am running with my 306.
Manley spring part number-
22410-16
.600 Max lift
1.250 OD Stock Chevy
Seat Pressure 130@1.750"
Open Pressure 320@1.200"
Coil Bind 1.150"
Some will say its not a good choice. The only reason I am using the spring is for the simple fact that I wanted proof that it would not work. I have put 1500 miles on mine and ran the **** out of it with absolutely no problems at all. Spin it up to 6400 with no problems.
22410-16
.600 Max lift
Coil Bind 1.150"
10-31-2016 11:09 AM
