Checking pushrod length..where to get a single solid lifter?
It makes sense to measure for your required pushrod length using a solid lifter, alot of the instructions I've read do not mention that, but one or two did since you want to check for the max lift travel while checking the geometery as you do not know just how much a hydraulic lifter will collaspe at high rpms...
So with that said....where can you buy just 1 solid roller lifter?? All I can find are entire sets and I sure don't need to buy a whole set of 16.
Get a hydro lifter, take it apart and shim it up so it wont collapse. You can easily do this with one of your good 16. I have even used a very light spring from the hardware store if the lifter is holding oil while turning the oil pump with a drill.
Just be sure that the old ones are the same as whatever new ones you are going to use. When I replaced the stock GM lifters with CC 850-16's, I found that there was quite a difference in the depth of the pushrod cups between the two.
teal98
15
09-16-2002 01:23 PM
danielbmx
08-27-2002 11:11 PM
johnsocal
21
08-17-2002 01:06 AM
SilverWS6
13
08-14-2002 09:29 PM
newby
10
07-27-2002 11:39 AM
