Clack Clack Clack sound
I've had the hot cam installed for about two weeks. Today i notice a clack clack clack clack sound coming from my engine. I can't really tell which valve cover its coming from. Is this an indication of a loose rocker arm? I'm 100% positive i did it right the first time. Could one have come loose. This started after I was running with lower oil pressure than normal b/c of the oil I used. I barely ran with the lower oil pressure before i swapped out the oil. Please help, as i need to fix this tomorrow morning.
Originally posted by shoebox
Post a link to your rod knock video! That will tell him for sure if that is what it is.
Yeah...my videos are called clack1.mpg and clack2.mpg....I hope you have a click or a tap and not a clack.
http://paradox.shacknet.nu/dave88lx/formula/clack1.mpg
http://paradox.shacknet.nu/dave88lx/formula/clack2.mpg
It has that classic tone and rhythm.......and you can dance to it.
I wish I had taken some sound bytes of mine. I had a few classic squeaks with it, too.
Originally posted by JJ's95B4C
Spun rod bearing means what...rebuild time? It doesn't quite sound like that...not as loud or constant like that.
Crank
pistons
rods
camshaft
lifters
oil pump
I think that's about it.
Then I went overboard and have a badarse 383 "in the works".
I'm starting to think it is the bearing. Its not coming directly from the valve covers, more like the area of the intake manifold. I'll pull the valve covers tomorrow and check my rockers. I really, really cant afford a rebuild.
http://paradox.shacknet.nu/dave88lx/formula/knock/
If it is just a bearing and nothing else, can it be fixed with the engine in the car, or does it need to be pulled?
