Cleaning the IAC
#16
Originally posted by 96Z28SilverStreak
I took mine apart and cleaned it as described above. After I put it back together. Now when I crank my car it idles up to about 2k then down to about 1200 rpms. I replaced my Iac and put new gaskets on eveything. I am still having this problem.
Any ideas?
Any ideas?
IAC reset
-Depress accelerator slightly
-Start engine, then release accelerator pedal, run engine for 5 seconds
-Turn ignition "OFF" for ten seconds
-Restart engine and check for proper idle operation
#17
how to avoid damaging the pintle
My newly acquired '95 Trans Am has a high idle when I start it approx 5-10min after driving it (engine is still warm), which dies down after maybe 10-15secs.
I'm planning to clean the TB and IAC this weekend but am worried that I'll damage the 'pintle' (to clarify, is this the part attached to the spring??) how can I do this without making my idle worse? I've cleaned my TB on my 3rd gen before, but only while it was on the car, I've heard this can cause the carbon buildup to seep into and plug the IAC?
all help appreciated
Brian
Brian
#18
ttt
having the same issue: 2000rpms for approx 10secs when starting the engine shortly after turning it off... the idles then drop to ~1200. could someone elaborate on what part of the tb or iac may be causing this? i have not yet unbolted or cleaned my tb or iac, i do plan to this weekend and need to know where to be xtra careful
thanks
brian
thanks
brian
#19
ttt
any help please? i've been reading about people having more problems than prior to cleaning due to altering the pintle position - i already have a high-rev start-up as described above, is it still a good idea to clean the tb and iac?
#20
Originally posted by pvkn1ght
ttt
ttt
#21
question: when removing the tb from the plenum, is it totally safe to remove the two rubber hoses on the passenger side of the tb when the engine is off? is there going to be any coolant coming out?
thanks - brian
thanks - brian
#22
thanks - brian
thanks - brian
tdigger9899
09-07-2015 10:56 AM
